주요 콘텐츠로 건너뛰기
Mac Pro 2009-2012 CPU Replacement
필요한 것
  1. Mac Pro 2009-2012 CPU  Replacement, Pull out CPU tray: 1 단계, 이미지 3개 중 1개 Mac Pro 2009-2012 CPU  Replacement, Pull out CPU tray: 1 단계, 이미지 3개 중 2개 Mac Pro 2009-2012 CPU  Replacement, Pull out CPU tray: 1 단계, 이미지 3개 중 3개
    • Find the 2 pull tabs and use them to pull out the CPU tray and place them on the table.
    • Use a hex wrench to unscrew the spring-loaded screw using the star pattern on the CPU Heatsink for even force of the CPU die. This is a specially needed when putting the Heatsink back on.
    • Turn the hex wrench once each time until it's loose when Using the star pattern (Diagram shown).
    • On 2009 (4,1) Mac Pros, The CPU comes up with the Heatsink and is not socketed. Like the 2010-2012 (5,1) Mac Pros.
    • Pull Straight up as there is a vital connection built into the heatsink.
    • On the bottom of the heatsink will be a copper pad that comes in contact with the CPU. Use a paper towel to wipe off all the remaining thermal paste, isopropyl Alcohol is handy for this.
    • Isopropyl alcohol is handy for getting the best for cleaning the Copper Heatsink&CPU for new thermal paste.
  2. Mac Pro 2009-2012 CPU  Replacement, CPU replacement: 2 단계, 이미지 3개 중 1개 Mac Pro 2009-2012 CPU  Replacement, CPU replacement: 2 단계, 이미지 3개 중 2개 Mac Pro 2009-2012 CPU  Replacement, CPU replacement: 2 단계, 이미지 3개 중 3개
    • Clean all of the thermal paste on the CPU and lift the metal bar up and pull the bracket back.
    • Gently pull out the old CPU with thumb and pointer finger and then place it towards the side.
    • Don't touch the exposed connectors on the CPU to the CPU tray.
  3. Mac Pro 2009-2012 CPU  Replacement, New CPU: 3 단계, 이미지 3개 중 1개 Mac Pro 2009-2012 CPU  Replacement, New CPU: 3 단계, 이미지 3개 중 2개 Mac Pro 2009-2012 CPU  Replacement, New CPU: 3 단계, 이미지 3개 중 3개
    • Inspect the cpu socket and other connectors for dust and debris and blow away if necessary.
    • Place the new cpu in with a touch of thermal paste at the top.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Branning Goody
회원 가입일: 01/24/22
301 평판
안내서 2개를 작성함
3가이드 댓글
This process shows a single CPU MacPro, which gets a Xeon processor WITH the LID covering it and heatsink on it. As of MacPro4,1 with Nehalem it's bi-xeon CPU and heatsink on a bare processor chip, no lid covers. That difference cannot be seen from a built MacPro board (because of the big heatsinks-) But it's a good performance improvement (CPU temp the lower the faster) when heatsink's directly in contact with the chip.
https://superuser.com/questions/923678/d...
If you can buy a Xeon upgrade just be sure to choose the processor without the lid (most Apple Mac setups) or with the lid cover (as PC setups)
Ti B Rakotoarima - 답글
Your guide has been very useful. Best compliments. I'll follow you 4ever!
aureliogiovanardi - 답글
Glad to here!
Thanks for the positive feedback! @goodyb Good job!
Ben Capehart -
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 65
지난 30일: 218
전체 시간: 8,842
