주요 콘텐츠로 건너뛰기
Mac Pro 2019 RAM Module Replacement
필요한 것
  1. Mac Pro 2019 RAM Module Replacement, Unplug the cables: 1 단계, 이미지 1/3 Mac Pro 2019 RAM Module Replacement, Unplug the cables: 1 단계, 이미지 2/3 Mac Pro 2019 RAM Module Replacement, Unplug the cables: 1 단계, 이미지 3/3
    • Shut down your Mac Pro.
    • Touch the metal housing with a bare hand to discharge any static electricity.
    • Unplug all cables from the Mac Pro, including the power cable.
  2. Mac Pro 2019 RAM Module Replacement, Unlock the housing: 2 단계, 이미지 1/3 Mac Pro 2019 RAM Module Replacement, Unlock the housing: 2 단계, 이미지 2/3 Mac Pro 2019 RAM Module Replacement, Unlock the housing: 2 단계, 이미지 3/3
    • Lift the top latch up from its recess.
    • Twist the latch counter-clockwise until it won't turn anymore—about a quarter-turn.
    • Slowly lift the housing up by the latch.
  3. Mac Pro 2019 RAM Module Replacement, Remove the housing: 3 단계, 이미지 1/1
    • Remove the housing.
  4. Mac Pro 2019 RAM Module Replacement, RAM Module: 4 단계, 이미지 1/3 Mac Pro 2019 RAM Module Replacement, RAM Module: 4 단계, 이미지 2/3 Mac Pro 2019 RAM Module Replacement, RAM Module: 4 단계, 이미지 3/3
    • The Mac Pro contains two RAM banks, each covered with a plastic cover.
    • Use your finger to slide the RAM cover latch to the left to unlock the cover.
    • When you reinstall the RAM cover, make sure that it securely clicks back in place.
  5. Mac Pro 2019 RAM Module Replacement, Remove the RAM cover: 5 단계, 이미지 1/3 Mac Pro 2019 RAM Module Replacement, Remove the RAM cover: 5 단계, 이미지 2/3 Mac Pro 2019 RAM Module Replacement, Remove the RAM cover: 5 단계, 이미지 3/3
    • Swing the released edge back towards the computer slightly, then pull the cover straight out and away from the Mac Pro.
  6. Mac Pro 2019 RAM Module Replacement, Unlock the RAM module: 6 단계, 이미지 1/2 Mac Pro 2019 RAM Module Replacement, Unlock the RAM module: 6 단계, 이미지 2/2
    • Each RAM module is locked in place by two lock tabs.
    • Use your fingers to push and spread the two lock tabs outwards, in order to unlock and eject the RAM module.
  7. Mac Pro 2019 RAM Module Replacement, Remove the RAM module: 7 단계, 이미지 1/2 Mac Pro 2019 RAM Module Replacement, Remove the RAM module: 7 단계, 이미지 2/2
    • Grasp the RAM module by the edges and pull it straight out of the slot.
    • Be careful not to twist the module as you pull it out.
    • Always handle the RAM module by the edges. Do not touch the gold contacts, as finger oils and ESD can damage the module.
  8. Mac Pro 2019 RAM Module Replacement, Install a RAM module: 8 단계, 이미지 1/3 Mac Pro 2019 RAM Module Replacement, Install a RAM module: 8 단계, 이미지 2/3 Mac Pro 2019 RAM Module Replacement, Install a RAM module: 8 단계, 이미지 3/3
    • To install a RAM module:
    • Gently slide the module into the slot.
    • Visually confirm that the notch between the module's gold contacts aligns with the receiving slot.
    • Firmly push both edges of the module to seat the RAM module into the slot.
    • As you push, do not bend or twist the RAM module.
    • As the module slides into position, the lock tabs along each edge should click back in place.
    • Make sure that both locking tabs rest securely in the RAM module's indents.
결론
To reassemble your Mac Pro, follow these instructions in reverse order.
If your Mac Pro won’t boot up after installing new RAM, check the status indicator light to help determine the problem.
Check out our Mac Pro Answers community for troubleshooting help.
다른 5명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
252,726 평판
안내서 526개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 한 개
can we use the ram on PC?
Fara Fara - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 23
30일 전: 80
전체 시간: 4,787
