주요 콘텐츠로 건너뛰기
Mac Pro First Generation Optical Drive Replacement
필요한 것
  1. Mac Pro First Generation Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Lift the lever to unlock the case
  2. Mac Pro First Generation Optical Drive Replacement: 2 단계, 이미지 1/1
    • Remove the side panel of the Mac Pro
  3. Mac Pro First Generation Optical Drive Replacement: 3 단계, 이미지 1/3 Mac Pro First Generation Optical Drive Replacement: 3 단계, 이미지 2/3 Mac Pro First Generation Optical Drive Replacement: 3 단계, 이미지 3/3
    • Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
  4. Mac Pro First Generation Optical Drive Replacement: 4 단계, 이미지 1/1
    • Firmly hold each of the two connectors and pull them out of their respective sockets.
  5. Mac Pro First Generation Optical Drive Replacement: 5 단계, 이미지 1/2 Mac Pro First Generation Optical Drive Replacement: 5 단계, 이미지 2/2
    • Unscrew the shown two 6-32 type screws on each side of the optical drive.
  6. Mac Pro First Generation Optical Drive Replacement: 6 단계, 이미지 1/2 Mac Pro First Generation Optical Drive Replacement: 6 단계, 이미지 2/2
    • Firmly grasp the optical drive and pull it out of its enclosure.
    To make the pull easier without pluming the whole body over- pull with your fingers and brace your thumbs on the tower chassis above - worked for me.
    Nick Rogers - 답글
    Correction, for pluming read pulling!
    Nick Rogers - 답글
결론
다른 21명이 해당 안내서를 완성하였습니다.
Derek Chan
회원 가입일: 10/13/14
1,416 평판
안내서 1개 작성함
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 회원
CPSU-MANESS-F14S6G24
4 회원들
안내서 13개 작성하였습니다
댓글 10개
Thanks! It had been a long time since I'd been inside my towers! Easy-peasy!
Janie Wilson-Cook - 답글
I am having problems with the new optical drive not being able to eject and close without my help. Any thoughts?
footeking - 답글
Did you take off the front of the tray?
nbeijer -
Awesome!!! Worked like a charm! Drive is totally busted. Do you have a link or a suggestion for an optical drive for a late 2009 Mac pro? Thanks either way!
Jay Haser - 답글
The unit holding the optical drive will NOT pull out at all and I and really pulling on it and wiggling it. All other videos show it popping out with little force. What am I doing wrong?
pipevape - 답글
I am having the same problem did you figure out what was wrong?
Tony Bounsall -
Probably just stuck. I’ve had mine out several times before, but the lever at the back of the case must be open. When it’s closed, it locks it in.
Aquenon -
I am having the same problem . I raised the lever handle no problem---Is there another interlock ?
Chuck Hendricks -
I am having the same problem. The lever arm comes up and stays up no Problem. Is there another interlock to release the optical drive door ?
vamochuck@gmail.com
Chuck Hendricks -
I am having the same problem. Any solution ?
vamochuck@gmail.com
Chuck Hendricks -
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 57
전체 시간: 16,733
