소개
The Mac Pro (Early 2008) logic board includes one double-wide PCI Express graphics slot and three PCI Express expansion slots, for a total of four slots. The computer comes with a graphics card installed in slot 1. You can install additional PCI Express graphics and expansion cards in the remaining three PCI Express expansion slots.
Important: Graphics cards from previous Power Mac G5 models are not compatible with Mac Pro (Early 2008) models. In addition, Mac Pro (Early 2008) graphics cards are not compatible with previous models.
Important: Combined maximum power consumption for all four PCI Express slots must not exceed 300 W.
도구
부품
Shut down the computer.
Wait 5 to 10 minutes to allow the computer’s internal components to cool.
Unplug all external cables from the computer except the power cord.
Touch the metal PCI access covers on the back of the computer to discharge any static electricity from your body.
Unplug the power cord.
Put on an ESD wrist strap.
This procedure explains how to remove a standard card and a card that includes a booster cable. Before you can remove either type of card, however, you must first loosen the two captive screws that secure the PCI bracket to the enclosure and remove the bracket.
Disconnect the booster cable(s) from the logic board.
Release the small locking clip at the front of the card’s logic board connector by pushing the clip up toward the media shelf.
Holding the card by the top corners, gently pull up the card and remove it from its expansion slot.
다른 35명이 해당 안내서를 완성하였습니다.
댓글 2개
1. In the step no 4, the picture itself was rotated 180' but the letters "1 " & "2" were not.
2. Is it better to show the small locking clip (of GPU) in logic board without GPU and with arrow direction in order to unlock (the GPU) ?
I know from personal experience that installing those booster cables (if not present) is the biggest pain in the butt part of this job. Other than that it is super easy and anyone can do it.
