주요 콘텐츠로 건너뛰기
Mac Pro Late 2013 AirPort Antenna Array Replacement
필요한 것
  1. Mac Pro Late 2013 AirPort Antenna Array Replacement, Outer Case: 1 단계, 이미지 1/2 Mac Pro Late 2013 AirPort Antenna Array Replacement, Outer Case: 1 단계, 이미지 2/2
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 AirPort Antenna Array Replacement: 2 단계, 이미지 1/3 Mac Pro Late 2013 AirPort Antenna Array Replacement: 2 단계, 이미지 2/3 Mac Pro Late 2013 AirPort Antenna Array Replacement: 2 단계, 이미지 3/3
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: 3 단계, 이미지 1/3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: 3 단계, 이미지 2/3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: 3 단계, 이미지 3/3
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. Mac Pro Late 2013 AirPort Antenna Array Replacement: 4 단계, 이미지 1/2 Mac Pro Late 2013 AirPort Antenna Array Replacement: 4 단계, 이미지 2/2
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 AirPort Antenna Array Replacement: 5 단계, 이미지 1/1
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Mac Pro Late 2013 AirPort Antenna Array Replacement: 6 단계, 이미지 1/1
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 AirPort Antenna Array Replacement: 7 단계, 이미지 1/2 Mac Pro Late 2013 AirPort Antenna Array Replacement: 7 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 AirPort Antenna Array Replacement: 8 단계, 이미지 1/1
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  9. Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: 9 단계, 이미지 1/3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: 9 단계, 이미지 2/3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: 9 단계, 이미지 3/3
    • Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
    • Remove the fan assembly lid.
  10. Mac Pro Late 2013 AirPort Antenna Array Replacement, AirPort Board: 10 단계, 이미지 1/1
    • Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
  11. Mac Pro Late 2013 AirPort Antenna Array Replacement: 11 단계, 이미지 1/1
    • Lift and remove the metal cover from the AirPort board bay.
  12. Mac Pro Late 2013 AirPort Antenna Array Replacement: 12 단계, 이미지 1/3 Mac Pro Late 2013 AirPort Antenna Array Replacement: 12 단계, 이미지 2/3 Mac Pro Late 2013 AirPort Antenna Array Replacement: 12 단계, 이미지 3/3
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector.
    • Remove the fan assembly ribbon cable from its ZIF socket.
  13. Mac Pro Late 2013 AirPort Antenna Array Replacement: 13 단계, 이미지 1/3 Mac Pro Late 2013 AirPort Antenna Array Replacement: 13 단계, 이미지 2/3 Mac Pro Late 2013 AirPort Antenna Array Replacement: 13 단계, 이미지 3/3
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable.
    • Disconnect the fan ribbon cable.
  14. Mac Pro Late 2013 AirPort Antenna Array Replacement, AirPort Antenna Array: 14 단계, 이미지 1/1
    • Remove the three 3.7 mm T4 screws securing the antenna array to the fan assembly.
  15. Mac Pro Late 2013 AirPort Antenna Array Replacement: 15 단계, 이미지 1/1
    • Remove the AirPort antenna array.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,810 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 2개
having macpro 2013 bluetooth on issue, where is the bluetooth module locate?
Sanong - 답글
is bluetooth module part of (inside) airport board?
Sanong - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 43
전체 시간: 5,283
