소개
Use this guide to replace the AirPort card in your Mac Pro Late 2013.
필요한 것
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
Remove the fan assembly lid.
Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
Use the tip of a spudger to disconnect the four AirPort antenna cables from the AirPort card.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 4개
Is there a way to replace the Mac Pro Airport card with a more recent one, like when you insert a recent one in an old macbook pro to get new features such as "unlock my mac with my apple watch" ? This is an interesting question that remains unanswered (until now ?)
I wondered the exact same thing. I can see zero reason to remove the fan assembly from the top of the machine just to replace the wifi card. The only reason I can see for doing it would be if you drop a screw it’s at least easy to get to, because everything is separate from the core unit.
