주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This Guide walks you through the steps to replace the original enclosure latch with a version that contains a hole for attaching a cable lock. This solution also prevents the enclosure from being able to be opened.
  1. Remove the enclosure by sliding the latch to the right and lifting the enclosure up.
    • Remove the enclosure by sliding the latch to the right and lifting the enclosure up.
    • Using a T5 screwdriver, remove the six screws retaining the latch on the inside of the enclosure and lift out the retainer plate.
  2. Remove the original latch, install the replacement latch with Kensington lock hole, and restore the retainer plate and six screws.
    • Remove the original latch, install the replacement latch with Kensington lock hole, and restore the retainer plate and six screws.
  3. Return the enclosure and slide the latch back to the left. Install cable lock into the exposed hole.
    • Return the enclosure and slide the latch back to the left. Install cable lock into the exposed hole.
결론
This guide will help you secure your Mac Pro (2013) with any cable lock.
다른 한 분이 해당 안내서를 완성하였습니다.
Kemper Barkhurst
회원 가입일: 2015년 07월 30일
149 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 1,607
