소개
Mac Pro는 단일 원심 팬 하나로 냉각됩니다. 이 안내서를 사용하여 팬을 청소하거나 교체하세요.
필요한 것
팬 어셈블리의 바깥 둘레에 있는 5.1mm T10 Torx 나사 다섯 개를 풀어주세요.
Fat Mango is correct. That said. If you do pull the fan assembly note that the screws are all held in with blue Permatex and breaking them free takes a fair amount of effort. Getting a good set of Torx screwdrivers is a must.
Jim WIlson - 답글
Hey guys, what would happen if you only replace one card.. I have a D300 but the plan is to upgrade to D500 or D600. So If I can afford and install one instead of the pair would it increase something? or will it cause any conflict? I guess I don’t understand if I the Mac Pro has 2 D300 graphic cards that means each has 1GB? Same as If I would Install 1 D600 that would increase 3GB only? Thanks.
D300 = 2GB each card. Very few apps uses two cards at the same time.
Gio Cas -
The (5) Screws are Apple part number 923-0713
한 손으로 팬 어셈블리를 받치면서 팬 케이블 브래킷에서 T8 고정 나사 두 개를 풀어주세요.
On my machine, a TR7 worked to remove them due to the weird angle.
스퍼저의 평평한 끝부분으로 팬 어셈블리 뚜껑을 냉각 어셈블리에서 들어올리세요.
팬 어셈블리 뚜껑을 분리하세요.
There is a thin circle of double sided adhesive that must be loosened in order to remove the plastic cover.
메탈 커버를 AirPort 보드 베이에 고정하는 3.7mm T4 나사 세 개를 풀어주세요.
I had better luck using a T5 driver.
Same here. Mine were T5, not T4.
t4 was good for me
팬 어셈블리를 팬에서 들어올리세요.
No way to install that last ribbon of a new fan is actually put on the last ribbon is attached
I would be happy to pay 100 dollars to find the solution for the last ribbon coennection when a new fan is actually put on
THANK YOU, now I know how to connect the ribbon to the fan again.
기기를 재조립하려면, 이 지침들을 역순으로 수행해주세요.
다른 14명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 5개
using my iFixit bit set, I'd have to say that the tiny screws for Airport card & cover, as well as fan bezel, are actually T5, not T4 - came very close to stripping the heads on two of the Airport card screws with the recommended T4 bit, but firm pressure and a steady hand with T5 bit got them out. Thanks for the guide - many careful steps to get a scrap of scotch tape out of the fan where its gentle ticks-ticka was driving us crazy thinking something far worse was going wrong.....
Ha! I wondered what would happen if some tiny flotsam was dropped in through the top - terrible! Thanks for the tip!
Likewise, I've had a random noise in the fan at startup, and finally took the fan assembly apart to grab it. It was some even tinier screw from somewhere that had lodged in part of the fan housing. All is very, very well now!!!!
Hey Colin, I have same fan startup nois in my MP. Can you help me and tell how to fix in few steps?
Deny -
Using Macs Fan Control, I noticed the baseline fan speed of my “trashcan” slowly creeping up from 790 RPM (the usual) to 8 or 900 RPM. Using this guide I took the fan assembly off, and vacuumed and dusted everything with a vacuum, soft brush and canned air. It wasn’t necessary to disassemble the fan unit itself. That did the trick - fan speed is back down to 790 RPM after putting it back together.
PS - in Step 5, a Torx T8 screwdriver seemed to fit just fine for the fan cable bracket screws.
