소개
The interconnect board hosts connections to the logic board, IO board, and both GPUs. Use this guide to remove and replace the interconnect board.
부품
지정된 부품이 없습니다.
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 4개
Why is it necessary to remove the fan?
