소개
Use this guide to replace the power supply in your Mac Pro Late 2013.
Before beginning any work on your Mac Pro: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
필요한 것
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
Use the flat end of a spudger to disconnect the power supply DC-Out connector from its socket on the IO board.
Use the tip of a spudger to disconnect the power supply data cable from its socket on the IO board.
다른 25명이 해당 안내서를 완성하였습니다.
댓글 7개
it works!
thanks much!
How do I purchase the Power Supply Module?
boinkboink - 답글
how did you make out? i just took my old PSU out, I was testing myself because I didn’t think I could actually take it apart!!! anyway, now I need to buy a new one. any suggestions?
Hi, please where can I buy the PSU ?
