주요 콘텐츠로 건너뛰기
Mac Pro Late 2013 RAM Replacement
  1. Mac Pro Late 2013 RAM Replacement, Outer Case: 1 단계, 이미지 1/2 Mac Pro Late 2013 RAM Replacement, Outer Case: 1 단계, 이미지 2/2
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 RAM Replacement: 2 단계, 이미지 1/3 Mac Pro Late 2013 RAM Replacement: 2 단계, 이미지 2/3 Mac Pro Late 2013 RAM Replacement: 2 단계, 이미지 3/3
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 RAM Replacement, RAM: 3 단계, 이미지 1/2 Mac Pro Late 2013 RAM Replacement, RAM: 3 단계, 이미지 2/2
    • Push the RAM release tab up.
    • The RAM slots will pivot outward to allow access to the RAM modules.
  4. Mac Pro Late 2013 RAM Replacement: 4 단계, 이미지 1/2 Mac Pro Late 2013 RAM Replacement: 4 단계, 이미지 2/2
    • Using two hands, pull the desired RAM module straight out of its slot.
    • To install new RAM modules, insert a new module into the appropriate slot, in the proper orientation. Press the RAM module into the slot until it is bottomed, then push the RAM tray back into the side of the Mac Pro.
결론
다른 40명이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,825 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 7개
How much RAM can I add? I saw Apple offering 64G, but also saw OCW offering 128G - is the CPU/MMU able to really handle this?
Peter Reif - 답글
Using Intel ARK to compare here is what they can support!
For the 4 Core CPU Supports: 256 GB
For the 6 Core CPU Supports: 256 GB
For the 8 Core CPU Supports: 768 GB
For the 12 Core CPU Supports: 768 GB
See: http://ark.intel.com/compare/75779,75780...
sokoal117 -
I would add this to the previous reply : what can you do with 768GB RAM that your 64/128GB mac can't handle ?
Vincent Monteil -
If I am only installing two sticks of ram, does anyone have a suggestion for what slots I should install them into? Thanks for yet another great guide! -George
George Mihaly - 답글
I have the same question and can't find an answer online. Apple doesn't ship them with less than 3 populated.
JRBv3 -
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 95
30일 전: 363
전체 시간: 32,263
