주요 콘텐츠로 건너뛰기
Mac Pro Late 2013 SSD Replacement
필요한 것
  1. Mac Pro Late 2013 SSD Replacement, Outer Case: 1 단계, 이미지 1/2 Mac Pro Late 2013 SSD Replacement, Outer Case: 1 단계, 이미지 2/2
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 SSD Replacement: 2 단계, 이미지 1/3 Mac Pro Late 2013 SSD Replacement: 2 단계, 이미지 2/3 Mac Pro Late 2013 SSD Replacement: 2 단계, 이미지 3/3
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 SSD Replacement, SSD: 3 단계, 이미지 1/1
    • Remove the single 6.5 mm T8 Torx screw.
  4. Mac Pro Late 2013 SSD Replacement: 4 단계, 이미지 1/3 Mac Pro Late 2013 SSD Replacement: 4 단계, 이미지 2/3 Mac Pro Late 2013 SSD Replacement: 4 단계, 이미지 3/3
    • Pull the SSD slightly away from the graphics card.
    • Do not pull the top edge of the SSD more than 1/2" away from the graphics card, or you will risk damaging it.
    • Lift the SSD straight up out of its slot on the graphics card.
결론
다른 40명이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,849 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 8개
Will a 970 evo 512 gb pcie m2 fit on here?
Sam Yao - 답글
As long as the drive is not the Plus version, you may be able to use an adapter in order to use that SSD in your MacPro6,1:
https://www.amazon.com/Sintech-Adapter-U...
I have not tried this, but am, currently, researching a fix for a machine in my care.
Robert Maxwell -
Yes—works very well with the Sintech adaptor (and even with an EK-M.2 NVMe Heatsink — use thermal paste for longevity!).
Just did this yesterday and it’s a great/fast/easy upgrade.
ericbalog -
Do you need a heat sink in the SSD?
Cesar Cuenca - 답글
The stock (Samsung) drive(s) that shipped (from Apple) with these machines do not; unless the black, outer covering helps with heat. [???]
I have had both a Samsung MZ-JPU256T/0A1 (256GB) and Samsung MZ-KPU1T0T/0A1 (1TB) installed in my machine without issue.
Third-party drives may include or heatsink and/or require at least 10.13 (High Sierra).
Robert Maxwell -
댓글 쓰기
조회 통계:
24 시간 전: 46
7일 전: 204
30일 전: 887
전체 시간: 81,446
