주요 콘텐츠로 건너뛰기
Mac mini (2024) Front USB-C Ports Replacement
필요한 것
  1. Mac mini (2024) Front USB-C Ports Replacement, Before you begin: 1 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Before you begin: 1 단계, 이미지 2개 중 2개
    • Fully shut down your Mac mini and unplug all cables from it.
    • Flip over your Mac mini and place it on a clean, flat surface to avoid scratching the chassis.
  2. Mac mini (2024) Front USB-C Ports Replacement, Create a gap: 2 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Create a gap: 2 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement, Create a gap: 2 단계, 이미지 3개 중 3개
    • Using the Jimmy or other metal tools during this step could scratch the aluminum chassis; however, it's the simplest way to perform this step. Follow the alternate instructions to avoid scratching the aluminum.
    • Insert a Jimmy into the gap between the bottom cover and the chassis.
    • Pry up the bottom cover to create a gap.
    • Alternatively, you can insert the point of a spudger into one of the plastic vent holes and pry up to create a gap big enough to insert an opening pick into.
    • Keep the Jimmy inserted under the bottom cover.
  3. Mac mini (2024) Front USB-C Ports Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement, Insert an opening pick: 3 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap created by the Jimmy.
    • Remove the Jimmy.
  4. Mac mini (2024) Front USB-C Ports Replacement, Release the pins: 4 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Release the pins: 4 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement, Release the pins: 4 단계, 이미지 3개 중 3개
    • Slide the opening pick along the bottom cover until you feel it snag on a pin.
    • There are four pins total—one at each corner of the bottom cover.
    • Twist the pick to lift the pin out of its slot.
  5. Mac mini (2024) Front USB-C Ports Replacement: 5 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement: 5 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement: 5 단계, 이미지 3개 중 3개
    • Continue sliding and prying with the pick along the perimeter of the bottom cover to release the remaining pins.
    • Don't insert the pick more than an inch when sliding near the power button, as you risk damaging the cable.
    • During reassembly, press along the perimeter of the bottom until you hear and feel all four pins click back into place.
  6. Mac mini (2024) Front USB-C Ports Replacement: 6 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement: 6 단계, 이미지 2개 중 2개
    • Don't remove the bottom cover, as it's still connected to the Mac mini with a cable.
    • Lift the edge of the bottom cover opposite the power button and flip it over to expose the power button cable.
  7. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the power button: 7 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the power button: 7 단계, 이미지 2개 중 2개
    • The power button cable is very fragile! You don't have to disconnect it to access the internals— but it will require you to keep the bottom cover propped up.
    • To disconnect the cable and remove the bottom cover, follow the next two steps.
    • If you don't disconnect the cable, prop up the bottom cover to prevent straining the cable and skip the next two steps.
    • Grip the power button cable close to the head and pull it away from its socket to disconnect it.
  8. Mac mini (2024) Front USB-C Ports Replacement, Remove the bottom cover: 8 단계, 이미지 1개 중 1개
    • Remove the bottom cover.
  9. Mac mini (2024) Front USB-C Ports Replacement, Remove the inner plate screws: 9 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Remove the inner plate screws: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • While the Mac mini uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T5 Torx screwdriver to remove the twelve screws securing the inner plate:
    • Eight 3.4 mm‑long screws
    • Four 2.4 mm‑long screws
  10. Mac mini (2024) Front USB-C Ports Replacement, Separate the inner plate: 10 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Separate the inner plate: 10 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement, Separate the inner plate: 10 단계, 이미지 3개 중 3개
    • Insert the point of a spudger into one of the clips' slots on the inner plate.
    • Pry up the inner plate enough so you can grip the edge along the same side as the headphone jack.
  11. Mac mini (2024) Front USB-C Ports Replacement: 11 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement: 11 단계, 이미지 2개 중 2개
    • Pull the inner plate away from the chassis to slide it out from under the lip on the heat sink.
    • During reassembly, slide the inner plate back under the heat sink and press along its edges to secure it in the chassis.
  12. Mac mini (2024) Front USB-C Ports Replacement: 12 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement: 12 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement: 12 단계, 이미지 3개 중 3개
    • Don't remove the inner plate yet, as it's still connected to the Mac mini by a cable.
    • Lift the inner plate and flip it over to expose the wireless module cable.
  13. Mac mini (2024) Front USB-C Ports Replacement, Remove the wireless module cover: 13 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Remove the wireless module cover: 13 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement, Remove the wireless module cover: 13 단계, 이미지 3개 중 3개
    • Use one hand to secure the wireless module during this step.
    • Use a Torx Plus 5IP screwdriver to remove the four 2.5 mm‑long screws securing the wireless module cover.
  14. Mac mini (2024) Front USB-C Ports Replacement, Remove the cover: 14 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Remove the cover: 14 단계, 이미지 2개 중 2개
    • Remove the wireless module cover.
    • During reassembly, look the bottom of the cover to find the foam rectangle. Align the foam rectangle over the wireless module press connector to find the proper orientation for the cover.
  15. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the wireless module: 15 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the wireless module: 15 단계, 이미지 2개 중 2개
    • Insert the point of a spudger under one of the short edges of the wireless module press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface-mounted components.
    • Pry up to disconnect the wireless module.
  16. Mac mini (2024) Front USB-C Ports Replacement, Remove the inner plate: 16 단계, 이미지 1개 중 1개
    • Remove the inner plate.
  17. Mac mini (2024) Front USB-C Ports Replacement, Remove the fan screws: 17 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Remove the fan screws: 17 단계, 이미지 2개 중 2개
    • If you're following this guide to clean your fan, this is a good time to do so.
    • Remove the four screws securing the fan:
    • Two 2.4 mm‑long Torx Plus 3IP screws
    • Two 7.9 mm‑long Torx Plus 5IP screws
  18. Mac mini (2024) Front USB-C Ports Replacement, Reposition the fan: 18 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Reposition the fan: 18 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement, Reposition the fan: 18 단계, 이미지 3개 중 3개
    • Lift the fan out of its recess in the chassis and flip it over to expose its wire and connector.
    • Let the fan rest on the chassis and heat sink.
  19. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the fan: 19 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the fan: 19 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the fan: 19 단계, 이미지 3개 중 3개
    • Use tweezers to peel back the tape covering the fan ZIF connector.
  20. Mac mini (2024) Front USB-C Ports Replacement: 20 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement: 20 단계, 이미지 2개 중 2개
    • Use the point of a spudger, or your fingernail, to flip up the locking tab on the fan ZIF connector.
  21. Mac mini (2024) Front USB-C Ports Replacement: 21 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement: 21 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to slide the ZIF connector straight out of its socket.
  22. Mac mini (2024) Front USB-C Ports Replacement, Remove the fan: 22 단계, 이미지 1개 중 1개
    • Remove the fan.
  23. Mac mini (2024) Front USB-C Ports Replacement, Remove the speaker screws: 23 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Remove the speaker screws: 23 단계, 이미지 2개 중 2개
    • Use a Torx Plus 5IP screwdriver to remove the three screws securing the speaker:
    • Two 4.1 mm‑long screws
    • One 3.7 mm‑long screw
  24. Mac mini (2024) Front USB-C Ports Replacement, Reposition the speaker: 24 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Reposition the speaker: 24 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement, Reposition the speaker: 24 단계, 이미지 3개 중 3개
  25. Mac mini (2024) Front USB-C Ports Replacement: 25 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement: 25 단계, 이미지 2개 중 2개
    • Pull the speaker over the edge of the chassis to expose its cable and its connector.
    • Rest the speaker on the edge of the chassis.
  26. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the speaker: 26 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the speaker: 26 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the speaker: 26 단계, 이미지 3개 중 3개
    • Grip the speaker cable close to the head and pull it away from its socket to disconnect it.
  27. Mac mini (2024) Front USB-C Ports Replacement, Remove the speaker: 27 단계, 이미지 1개 중 1개
    • Remove the speaker.
  28. Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port cover screws: 28 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port cover screws: 28 단계, 이미지 2개 중 2개
    • Remove the four screws securing the USB-C port cover:
    • Three 2.2 mm‑long Torx Plus 3IP screws
    • One 9.2 mm‑long Torx Plus 8IP screw
  29. Mac mini (2024) Front USB-C Ports Replacement, Remove the cover: 29 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Remove the cover: 29 단계, 이미지 2개 중 2개
    • Use tweezers, or your fingers, to remove the front USB-C port cover.
  30. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the front USB-C ports: 30 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the front USB-C ports: 30 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the front USB-C ports press connector.
  31. Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port screws: 31 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port screws: 31 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port screws: 31 단계, 이미지 3개 중 3개
    • Use a Torx Plus 3IP screwdriver to remove the four 4.7 mm‑long screws securing the two front USB-C ports.
    • If you aren't using a flexible adapter, make sure your screwdriver is as parallel with the screw as possible. Apply constant force against the screw to avoid stripping.
  32. Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C ports: 32 단계, 이미지 3개 중 1개 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C ports: 32 단계, 이미지 3개 중 2개 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C ports: 32 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry the front USB-C ports from their recesses in the chassis.
    • During reassembly, gently press the USB-C ports into their recesses until they click into place.
  33. Mac mini (2024) Front USB-C Ports Replacement: 33 단계, 이미지 2개 중 1개 Mac mini (2024) Front USB-C Ports Replacement: 33 단계, 이미지 2개 중 2개
    • Pull the front USB-C ports out of the chassis and remove it.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mac mini (2024) Answers Community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
212,810 평판
안내서 1,039개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,611개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 103
전체 시간: 1,511
