이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
Keep working around the perimeter, freeing the clips along the final edge.
Flip the Mac mini back over and lift the top housing off of the lower housing.
다른 12명이 해당 안내서를 완성하였습니다.
첨부 문서
댓글 2개
those Putty Knifes are:
too smal
too sharp
too expensive.
Better use a 100mm broad Spatula; (opens all the claws in on step)
out of plastic is good enough and cheap.
And use two of them at one time.
No, I didn’t think the Jimmy is expensive or too small.
And the Jimmy didn’t break something so it is the best solution I think!
