주요 콘텐츠로 건너뛰기
Mac mini Late 2012 Antenna Plate Replacement
필요한 것
  1. Mac mini Late 2012 Antenna Plate Replacement, Bottom Cover: 1 단계, 이미지 2개 중 1개 Mac mini Late 2012 Antenna Plate Replacement, Bottom Cover: 1 단계, 이미지 2개 중 2개
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
  2. Mac mini Late 2012 Antenna Plate Replacement: 2 단계, 이미지 1개 중 1개
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Mac mini Late 2012 Antenna Plate Replacement, Fan: 3 단계, 이미지 1개 중 1개
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Mac mini Late 2012 Antenna Plate Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
  5. Mac mini Late 2012 Antenna Plate Replacement: 5 단계, 이미지 3개 중 1개 Mac mini Late 2012 Antenna Plate Replacement: 5 단계, 이미지 3개 중 2개 Mac mini Late 2012 Antenna Plate Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
    • Do not pry at the socket, or you may rip it from the logic board.
    • Remove the fan.
  6. Mac mini Late 2012 Antenna Plate Replacement, Cowling: 6 단계, 이미지 1개 중 1개
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Mac mini Late 2012 Antenna Plate Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
  8. Mac mini Late 2012 Antenna Plate Replacement, Antenna Plate: 8 단계, 이미지 1개 중 1개
    • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
    • When putting back together:
    • It can be difficult to get the hard drive seated correctly such that the antenna plate fits in place correctly. If the screw holes don't line up with those on the hard drive, make sure that the two pins that are in the back of the hard drive are properly seated in the holes at the back of the case, above the housing for the second hard drive.
    • The antenna attaches directly to the hard drive (red markers), therefore attaching the antenna can move the hard drive around and loosen the connection of the hard drive cable to the logic board.
  9. Mac mini Late 2012 Antenna Plate Replacement: 9 단계, 이미지 2개 중 1개 Mac mini Late 2012 Antenna Plate Replacement: 9 단계, 이미지 2개 중 2개
    • Slightly lift the antenna plate from the end closest to the RAM.
    • Carefully pull the antenna plate away from the circular rim of the outer case.
    • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
  10. Mac mini Late 2012 Antenna Plate Replacement: 10 단계, 이미지 1개 중 1개
    • Use the tip of a spudger to carefully pry the antenna connector up from its socket on the AirPort/Bluetooth board.
  11. Mac mini Late 2012 Antenna Plate Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the antenna plate from the mini.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Optimus Goldheart
회원 가입일: 10/17/09
512,212 평판
안내서 407개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 47
전체 시간: 11,037
