주요 콘텐츠로 건너뛰기
소개
Problems with Wi-Fi or Bluetooth? You may have a faulty AirPort card. Use this guide to replace the AirPort card in your Mac mini Late 2014.
  1. The bottom cover is clipped onto three screw posts.
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Use the plastic opening tool to pry the bottom cover up off of the Mac mini. Use the plastic opening tool to pry the bottom cover up off of the Mac mini. Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Lift and remove the bottom cover. Lift and remove the bottom cover.
    • Lift and remove the bottom cover.
  4. Remove the following TR6 screws from the antenna plate:
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable. With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card. Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Carefully pull the antenna cable out from the gap between the power supply and case. Carefully pull the antenna cable out from the gap between the power supply and case.
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Remove the antenna plate from the Mac mini.
    • Remove the antenna plate from the Mac mini.
  10. Remove the single 3.4 mm T6 screw and washer from the antenna cable.
  11. Use the point of a spudger to lift the antenna connectors up off their sockets. Use the point of a spudger to lift the antenna connectors up off their sockets. Use the point of a spudger to lift the antenna connectors up off their sockets.
    • Use the point of a spudger to lift the antenna connectors up off their sockets.
  12. Remove the 2.7 mm T5 screw securing the AirPort card.
    • Remove the 2.7 mm T5 screw securing the AirPort card.
  13. Lift the free end of the AirPort card enough to grasp it by the edges. Lift the free end of the AirPort card enough to grasp it by the edges. Lift the free end of the AirPort card enough to grasp it by the edges.
    • Lift the free end of the AirPort card enough to grasp it by the edges.
  14. Pull the AirPort card straight out of its socket on the logic board and remove it from the Mac mini. Pull the AirPort card straight out of its socket on the logic board and remove it from the Mac mini.
    • Pull the AirPort card straight out of its socket on the logic board and remove it from the Mac mini.
결론
다른 15명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 2012년 10월 18일
442,270 평판
안내서 547개 작성하였습니다
iFixit iFixit 회원
Community
138 회원들
안내서 16,981개 작성하였습니다
댓글 4개
Thanks. Took all of 20 minutes start to finish to upgrade my broken NIC.
Erik Westlund - 답글
Hmm, look like an M.2 interface, could an M.2 SSD be installed instead?
The Bionic Cyclist - 답글
Can confirm that the airport card for the 2015 Macbook Pro fits and functions perfectly as a replacement if you can’t find the mac mini one.
Sam Goddard - 답글
If something wrong with my bluetooth, is it also replace this logic board ?
Gordon Lee - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 31
30일 전: 159
전체 시간: 14,883
