주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    The bottom cover is clipped onto three screw posts.
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use the plastic opening tool to pry the bottom cover up off of the Mac mini. Use the plastic opening tool to pry the bottom cover up off of the Mac mini. Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Lift and remove the bottom cover. Lift and remove the bottom cover.
    • Lift and remove the bottom cover.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the following TR6 screws from the antenna plate:
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable. With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card. Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Carefully pull the antenna cable out from the gap between the power supply and case. Carefully pull the antenna cable out from the gap between the power supply and case.
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the antenna plate from the Mac mini.
    • Remove the antenna plate from the Mac mini.
  10. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the 5 mm T5 screw securing the SSD.
    • Remove the 5 mm T5 screw securing the SSD.
  11. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Lift the free end of the SSD up slightly and pull it out of its socket. Lift the free end of the SSD up slightly and pull it out of its socket. Lift the free end of the SSD up slightly and pull it out of its socket.
    • Lift the free end of the SSD up slightly and pull it out of its socket.
  12. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Carefully lift the SSD out of the case without scratching or touching the gold contacts. Carefully lift the SSD out of the case without scratching or touching the gold contacts. Carefully lift the SSD out of the case without scratching or touching the gold contacts.
    • Carefully lift the SSD out of the case without scratching or touching the gold contacts.
결승점
다른 79명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 2012년 10월 18일
436,499 평판
안내서 547개 작성하였습니다
iFixit iFixit 회원
Community
134 회원들
안내서 15,629개 작성하였습니다
If I have a Mac Mini without SSD, only with normal Hard Drive (NO Fusion). Can I install a new one SSD like on this tutorial?. Thanks!
Juan Miguel Ramirez - 답글
Please see my comment later in the thread.
Thomas Hall -
Si, yo lo hice y la diferencia es abismal. Necesitaras un adaptador y por supuesto el SSD. Yes, I did it and the difference is abysmal. You will need an adapter and of course the SSD.
Manuel Jesús Flores Jiménez -
I have the same question as Juan
Cronan McNamara - 답글
yes But You Need To Buy Parts Used Ifixet Or Ebay
william petreman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 38
7일 전: 235
30일 전: 1,185
전체 시간: 132,378
