주요 콘텐츠로 건너뛰기
소개
Use this guide to replace a faulty speaker in your Mac mini Late 2014.
This guide was made with a Fusion Drive Mac mini, and may have more connectors and components than your model. Don't be alarmed if you're missing a hard drive or SSD connector!
  1. The bottom cover is clipped onto three screw posts.
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Use the plastic opening tool to pry the bottom cover up off of the Mac mini. Use the plastic opening tool to pry the bottom cover up off of the Mac mini. Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Lift and remove the bottom cover. Lift and remove the bottom cover.
    • Lift and remove the bottom cover.
  4. Remove the following TR6 screws from the antenna plate:
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable. With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card. Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Carefully pull the antenna cable out from the gap between the power supply and case. Carefully pull the antenna cable out from the gap between the power supply and case.
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Remove the antenna plate from the Mac mini.
    • Remove the antenna plate from the Mac mini.
  10. Remove the two 12 mm T6 screws from the fan.
    • Remove the two 12 mm T6 screws from the fan.
    • Loosen the 27 mm T6 captive screw.
  11. The fan connector is trapped under the edge of the fan and cannot be disconnected until the fan is moved. Do not attempt to remove the fan entirely. Lift the fan straight up to free the captive screw from its hole in the logic board.
    • The fan connector is trapped under the edge of the fan and cannot be disconnected until the fan is moved.
    • Do not attempt to remove the fan entirely.
    • Lift the fan straight up to free the captive screw from its hole in the logic board.
    • Pull the fan away from the SSD until you can easily access the fan connector.
  12. Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board. Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
    • Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
  13. Remove the fan from the Mac mini.
    • Remove the fan from the Mac mini.
  14. Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
    • Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
  15. Remove the SATA cable connector bracket. Remove the SATA cable connector bracket.
    • Remove the SATA cable connector bracket.
  16. Use the flat end of a spudger to lift the SATA cable connector up off of its socket on the logic board. Use the flat end of a spudger to lift the SATA cable connector up off of its socket on the logic board.
    • Use the flat end of a spudger to lift the SATA cable connector up off of its socket on the logic board.
  17. Use the tip of a spudger to disconnect the IR sensor cable connector by prying it straight up from its socket. Use the tip of a spudger to disconnect the IR sensor cable connector by prying it straight up from its socket.
    • Use the tip of a spudger to disconnect the IR sensor cable connector by prying it straight up from its socket.
  18. The following three steps only apply to Mac minis equipped with a PCIe SSD. Skip the next three steps if your Mac mini only has a hard drive.
    • The following three steps only apply to Mac minis equipped with a PCIe SSD. Skip the next three steps if your Mac mini only has a hard drive.
    • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
  19. Remove the PCIe SSD cable bracket. Remove the PCIe SSD cable bracket.
    • Remove the PCIe SSD cable bracket.
  20. Lift the PCIe SSD connector up off its socket. Lift the PCIe SSD connector up off its socket.
    • Lift the PCIe SSD connector up off its socket.
  21. Remove the single 16 mm T6 screw securing the logic board.
    • Remove the single 16 mm T6 screw securing the logic board.
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
  22. Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case. Cease prying when the removal tool makes contact with the opening in the rear case. Remove the Mac mini Logic Board Removal tool.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the removal tool makes contact with the opening in the rear case.
    • Remove the Mac mini Logic Board Removal tool.
  23. Pull the DC-In cable connector straight out of its socket on the logic board. Pull the DC-In cable connector straight out of its socket on the logic board.
    • Pull the DC-In cable connector straight out of its socket on the logic board.
  24. Carefully slide the logic board assembly out of the Mac mini, minding any cables that may get caught. Carefully slide the logic board assembly out of the Mac mini, minding any cables that may get caught.
    • Carefully slide the logic board assembly out of the Mac mini, minding any cables that may get caught.
  25. Remove the following T6 Torx screws securing the speaker to the logic board:
    • Remove the following T6 Torx screws securing the speaker to the logic board:
    • One 3.6 mm screw
    • One 3.6 mm large headed screw
  26. Do not attempt to remove the speaker entirely as it is still attached to the logic board. Nudge the speaker gently out of the way to allow access to the speaker's connector.
    • Do not attempt to remove the speaker entirely as it is still attached to the logic board.
    • Nudge the speaker gently out of the way to allow access to the speaker's connector.
  27. Use the flat end of a spudger to carefully lift the speaker connector up out of its socket on the logic board. Remove the speaker from the logic board. Remove the speaker from the logic board.
    • Use the flat end of a spudger to carefully lift the speaker connector up out of its socket on the logic board.
    • Remove the speaker from the logic board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 2012년 10월 18일
389,796 평판
안내서 545개 작성하였습니다
iFixit iFixit 회원
Community
108 회원들
안내서 9,537개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 28
전체 시간: 2,321
