이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace a noisy worn-out fan.
필요한 것
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
다른 32명이 해당 안내서를 완성하였습니다.
댓글 3개
step 3 should have note to remove 3 ea. screws ... the screw on the left bottom on the picture is not shown ... it is obvious when you look at the fan you recieve ... connector came out very easy, just pull up (easily) ... took less than 15 minutes on my i7 server mini, mid 2011 model
DiSH
