소개
Replace a faulty AirPort antenna to regain wireless internet connectivity.
부품
지정된 부품이 없습니다.
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Use the flat end of a spudger to pry the AirPort antenna cable connector up off the AirPort card.
다른 38명이 해당 안내서를 완성하였습니다.
