주요 콘텐츠로 건너뛰기
MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement
필요한 것
  1. MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement, Battery Connector: 3 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement, Battery Connector: 3 단계, 이미지 2개 중 2개
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: 4 단계, 이미지 3개 중 1개 MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: 4 단계, 이미지 3개 중 2개 MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: 4 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way of the card.
  5. MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement: 6 단계, 이미지 3개 중 1개 MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement: 6 단계, 이미지 3개 중 2개 MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement: 6 단계, 이미지 3개 중 3개
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it straight out of its socket on the logic board.
    • To avoid damaging the socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Miroslav Djuric
160,248 평판
안내서 144개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 20
전체 시간: 6,010
