소개
Use this guide to replace a damaged heat sink or to reapply its thermal paste.
Be sure to apply a new layer of thermal paste before reinstalling your heat sink.
필요한 것
이 단계에 사용된 도구:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
Remove the four 2.5 mm T5 Torx screws securing the heat sink to the logic board.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
you should seriously note the danger of the cpu screw holders. apple for some reason decided to attach the fricken screw receivers/standoffs via surface mount. they dont have a bottom cap either. use a screw slightly too long or turn too far and pop(screw pushes against motherboard and pops the holder off)... one corner is unable to be screwed in. ask me how i learned this...lol...I cant see how this design decision helps anything but apples wallet. the other side of the board has components smds as well so its not like a really short through hole was undo-able.
There is step missing between 3 and 4. There is another ribbon cable over fan that is still there in step 3 but gone in step 4.
