주요 콘텐츠로 건너뛰기
MacBook Air 11" Early 2014 I/O Board Replacement
필요한 것
  1. MacBook Air 11" Early 2014 I/O Board Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2014 I/O Board Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2014 I/O Board Replacement, Battery Connector: 3 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement, Battery Connector: 3 단계, 이미지 2개 중 2개
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Early 2014 I/O Board Replacement, I/O Board Cable: 4 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement, I/O Board Cable: 4 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Early 2014 I/O Board Replacement: 5 단계, 이미지 1개 중 1개
    • Lift and remove the I/O board cable.
  6. MacBook Air 11" Early 2014 I/O Board Replacement, Fan: 6 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement, Fan: 6 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  7. MacBook Air 11" Early 2014 I/O Board Replacement: 7 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement: 7 단계, 이미지 2개 중 2개
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  8. MacBook Air 11" Early 2014 I/O Board Replacement: 8 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement: 8 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Early 2014 I/O Board Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  10. MacBook Air 11" Early 2014 I/O Board Replacement: 10 단계, 이미지 3개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement: 10 단계, 이미지 3개 중 2개 MacBook Air 11" Early 2014 I/O Board Replacement: 10 단계, 이미지 3개 중 3개
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  11. MacBook Air 11" Early 2014 I/O Board Replacement, Battery: 11 단계, 이미지 1개 중 1개
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  12. MacBook Air 11" Early 2014 I/O Board Replacement: 12 단계, 이미지 1개 중 1개
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  13. MacBook Air 11" Early 2014 I/O Board Replacement, I/O Board: 13 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement, I/O Board: 13 단계, 이미지 2개 중 2개
    • Disconnect the I/O board power cable from the logic board by pulling the cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  14. MacBook Air 11" Early 2014 I/O Board Replacement: 14 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement: 14 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  15. MacBook Air 11" Early 2014 I/O Board Replacement: 15 단계, 이미지 3개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement: 15 단계, 이미지 3개 중 2개 MacBook Air 11" Early 2014 I/O Board Replacement: 15 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
  16. MacBook Air 11" Early 2014 I/O Board Replacement: 16 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement: 16 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry under the speaker cable near the connector to lift the connector straight up out of its socket.
  17. MacBook Air 11" Early 2014 I/O Board Replacement: 17 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement: 17 단계, 이미지 2개 중 2개
    • De-route the cable from its notch in the I/O board.
  18. MacBook Air 11" Early 2014 I/O Board Replacement: 18 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement: 18 단계, 이미지 2개 중 2개
    • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
  19. MacBook Air 11" Early 2014 I/O Board Replacement: 19 단계, 이미지 1개 중 1개
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
    • In some models this is a 3.1 mm T5 Torx screw.
  20. MacBook Air 11" Early 2014 I/O Board Replacement: 20 단계, 이미지 3개 중 1개 MacBook Air 11" Early 2014 I/O Board Replacement: 20 단계, 이미지 3개 중 2개 MacBook Air 11" Early 2014 I/O Board Replacement: 20 단계, 이미지 3개 중 3개
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
474,929 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
1가이드 댓글
Does the IO board on this model contain the hall effect sensor(lid sensor)? Where is it located and what does it look like?
Marik - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 112
전체 시간: 7,490
