주요 콘텐츠로 건너뛰기
MacBook Air 11" Late 2010 I/O Board Replacement
필요한 것
  1. MacBook Air 11" Late 2010 I/O Board Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Late 2010 I/O Board Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Late 2010 I/O Board Replacement, Battery: 3 단계, 이미지 2개 중 1개 MacBook Air 11" Late 2010 I/O Board Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Late 2010 I/O Board Replacement, Solid-State Drive: 4 단계, 이미지 1개 중 1개
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 11" Late 2010 I/O Board Replacement: 5 단계, 이미지 2개 중 1개 MacBook Air 11" Late 2010 I/O Board Replacement: 5 단계, 이미지 2개 중 2개
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  6. MacBook Air 11" Late 2010 I/O Board Replacement, I/O Board Cable: 6 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  7. MacBook Air 11" Late 2010 I/O Board Replacement: 7 단계, 이미지 1개 중 1개
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  8. MacBook Air 11" Late 2010 I/O Board Replacement, Fan: 8 단계, 이미지 1개 중 1개
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Late 2010 I/O Board Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 3.6 mm T5 Torx screw
  10. MacBook Air 11" Late 2010 I/O Board Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
  11. MacBook Air 11" Late 2010 I/O Board Replacement, I/O Board: 11 단계, 이미지 1개 중 1개
    • Remove the following five screws securing the battery to the upper case:
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  12. MacBook Air 11" Late 2010 I/O Board Replacement: 12 단계, 이미지 1개 중 1개
    • Do not touch or squeeze the six lithium polymer cells when handling the battery.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  13. MacBook Air 11" Late 2010 I/O Board Replacement: 13 단계, 이미지 1개 중 1개
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  14. MacBook Air 11" Late 2010 I/O Board Replacement: 14 단계, 이미지 2개 중 1개 MacBook Air 11" Late 2010 I/O Board Replacement: 14 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
  15. MacBook Air 11" Late 2010 I/O Board Replacement: 15 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
  16. MacBook Air 11" Late 2010 I/O Board Replacement: 16 단계, 이미지 1개 중 1개
    • Pull the camera cable parallel to the face of the I/O board toward the rear edge of the Air to disconnect it from its socket.
    • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
  17. MacBook Air 11" Late 2010 I/O Board Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
  18. MacBook Air 11" Late 2010 I/O Board Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  19. MacBook Air 11" Late 2010 I/O Board Replacement: 19 단계, 이미지 1개 중 1개
    • Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Bookholt
596,422 평판
안내서 619개를 작성함
1가이드 댓글
Question. Im looking a replacing the I/O board on my MacBook air and am wondering if it matters whether I get the board for the 13” or the 11”? Are the two boards different? It seems that the 11” I/O board is cheaper so I just trying to figure out if it matters which one I get?
Tristan cusi - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 81
전체 시간: 15,139
