주요 콘텐츠로 건너뛰기
MacBook Air 11" Mid 2013 Fan Replacement
필요한 것
  1. MacBook Air 11" Mid 2013 Fan Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2013 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2013 Fan Replacement, Battery Connector: 3 단계, 이미지 2개 중 1개 MacBook Air 11" Mid 2013 Fan Replacement, Battery Connector: 3 단계, 이미지 2개 중 2개
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Mid 2013 Fan Replacement, I/O Board Cable: 4 단계, 이미지 2개 중 1개 MacBook Air 11" Mid 2013 Fan Replacement, I/O Board Cable: 4 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Mid 2013 Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Lift and remove the I/O board cable.
  6. MacBook Air 11" Mid 2013 Fan Replacement, Fan: 6 단계, 이미지 2개 중 1개 MacBook Air 11" Mid 2013 Fan Replacement, Fan: 6 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  7. MacBook Air 11" Mid 2013 Fan Replacement: 7 단계, 이미지 2개 중 1개 MacBook Air 11" Mid 2013 Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  8. MacBook Air 11" Mid 2013 Fan Replacement: 8 단계, 이미지 2개 중 1개 MacBook Air 11" Mid 2013 Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Mid 2013 Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  10. MacBook Air 11" Mid 2013 Fan Replacement: 10 단계, 이미지 3개 중 1개 MacBook Air 11" Mid 2013 Fan Replacement: 10 단계, 이미지 3개 중 2개 MacBook Air 11" Mid 2013 Fan Replacement: 10 단계, 이미지 3개 중 3개
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
결론
다른 15명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
471,639 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,467개를 작성함
댓글 한 개
I have error PPF004.
Liviolog4 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 23
전체 시간: 6,478
