주요 콘텐츠로 건너뛰기
MacBook Air 11" Mid 2013 I/O Board Cable Replacement
필요한 것
  1. MacBook Air 11" Mid 2013 I/O Board Cable Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2013 I/O Board Cable Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2013 I/O Board Cable Replacement, Battery Connector: 3 단계, 이미지 2개 중 1개 MacBook Air 11" Mid 2013 I/O Board Cable Replacement, Battery Connector: 3 단계, 이미지 2개 중 2개
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Mid 2013 I/O Board Cable Replacement, I/O Board Cable: 4 단계, 이미지 2개 중 1개 MacBook Air 11" Mid 2013 I/O Board Cable Replacement, I/O Board Cable: 4 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Mid 2013 I/O Board Cable Replacement: 5 단계, 이미지 1개 중 1개
    • Lift and remove the I/O board cable.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
475,086 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 14
전체 시간: 2,793
