소개
Use this guide to replace the battery.
Note: If there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
필요한 것
이 단계에 사용된 도구:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Repair didn’t go as planned? Check out our MacBook Air 13" Early 2014 Answers Community for troubleshooting help.
다른 186명이 해당 안내서를 완성하였습니다.
댓글 22개
Thanks for this guide! From ordering the parts to doing to work, it was a super easy and fast process! May have been nice to see some mention of the different sized screws in various locations, and how to calibrate the battery once done with the install. Either way, awesome tutorial!
@ejhalsell Good point about calibration—that’s been added to the final step now. There are measurements for every single screw though, so I’m not sure what more you’re looking for there.
How best should I dispose of my old battery? Would be nice to include this information.
Thanks!
It’s hiding in the conclusion ;) “Take your e-waste to an R2 or e-Stewards certified recycler.” Thanks for disposing responsibly!
