소개
Use this guide to replace a noisy MacBook Air 13" Early 2015 fan, or simply remove it for cleaning.
동영상 개요
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
다른 34명이 해당 안내서를 완성하였습니다.
댓글 2개
Hello! I just broke the flap/hinge on the ZIF socket connecting the fan ribbon. What do I do now? Is a replacement ZIF socket available?
The zif connector just detached from the board when attempting to open the hinge with spudger. I’ve tried to solder the zif connector back to the board but the connector is so small that I haven’t been successful.
