소개
Use this guide to replace the I/O board's interconnect cable in your MacBook Air 13" Early 2015.
도구
부품
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
다른 7명이 해당 안내서를 완성하였습니다.
