소개
Use this guide to replace the I/O board, including the headphone jack, USB port, and MagSafe 2 port, in your MacBook Air 13" Early 2015.
필요한 것
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
다른 46명이 해당 안내서를 완성하였습니다.
댓글 15개
Ich habe ein Macbook Air 2015 early. Das Ladekabel leuchtet nicht und die Batterie wird nicht geladen, ohne Batterie läuft das Macbook und auch solange die Batterie geladen ist läuft es einwandfrei auch ohne Ladekabel. Woher bekomme ich das I-O board und denkt ihr es liegt am I-O board oder eher irgendwo auf dem Mainboard das Problem?
Man kann das I/O-board bei ebay finden, kostet nicht viel, der Austausch ist ja oben beschrieben, man muss da sehr vorsichtig vorgehen, zB das dünne, kurze Flexkabel ganz am Schluss.
Jamba -
I successfully fixed my Macbook Air early 2015. Power cord LED indicator was dark and the battery was not charging. This was because my power supply blew up while stuck within the couch and went dangerously hot. Power supply died as the IO Board too.
Replacing the IO Board fixed my Macbook.
Hi . I replaced my IO board because the power socket was burned. With the new board the Macbook air mid 2011 was running very slow. Changed back to the old one and computer was running as normal. Any Ideas why the new IO board was slowing the computer down. The USB port in the new board was also not working.
