주요 콘텐츠로 건너뛰기
MacBook Air 13" Early 2015 SSD Replacement
필요한 것
동영상 개요
  1. MacBook Air 13" Early 2015 SSD Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2015 SSD Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2015 SSD Replacement, Battery Connector: 3 단계, 이미지 2개 중 1개 MacBook Air 13" Early 2015 SSD Replacement, Battery Connector: 3 단계, 이미지 2개 중 2개
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2015 SSD Replacement, Solid-State Drive: 4 단계, 이미지 1개 중 1개
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 13" Early 2015 SSD Replacement: 5 단계, 이미지 2개 중 1개 MacBook Air 13" Early 2015 SSD Replacement: 5 단계, 이미지 2개 중 2개
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
결론
다른 213명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
475,074 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,779개를 작성함
51가이드 댓글
Great... Now tell me where I can get an SSD for this machine.
Dave - 답글
yes) and prompt and appropriate model that was not inferior in speed built.
Thank!
ilyabuhov -
Dave, I am sure these are M.2 SSD. I am not sure what apple uses but at least you have somewhere you can start for research
klacorum -
That’s indeed an M.2 SSD but you’ll need an adapter as the one that came with the Macbook uses a proprietary connector.
Farie Indriawan -
Is there a way to upgrade it ? I cant find a bigger SSD which can be installed on this model.
Any update is welcome.
Max - 답글
댓글 쓰기
조회 통계:
지난 24시간: 59
지난 7일: 341
지난 30일: 1,492
전체 시간: 493,674
