주요 콘텐츠로 건너뛰기
MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement
필요한 것
  1. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, Battery Connector: 3 단계, 이미지 2개 중 1개 MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, Battery Connector: 3 단계, 이미지 2개 중 2개
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 4 단계, 이미지 2개 중 1개 MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 4 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: 6 단계, 이미지 2개 중 1개 MacBook Air 13" Early 2017 AirPort/Bluetooth Card Replacement: 6 단계, 이미지 2개 중 2개
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Adam O'Camb
회원 가입일: 04/11/15
217,165 평판
안내서 416개를 작성함
1가이드 댓글
Perfect instructions,
Worked first time, without any issues!
THANK YOU :-)
Tahir Khan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 64
지난 30일: 330
전체 시간: 13,729
