소개
Use this guide to replace the double microphone assembly in your MacBook Air 13" Early 2017.
필요한 것
이 단계에 사용된 도구:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Remove the following five screws securing the battery to the upper case:
Three 6.9 mm T5 Torx screws
Two 3.0 mm T5 Torx screws
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Carefully peel, but do not remove, the I/O board cable off the adhesive securing it to the top of the fan.
다른 4명이 해당 안내서를 완성하였습니다.
