주요 콘텐츠로 건너뛰기
MacBook Air 13" Early 2017 SSD Upgrade to NVMe
필요한 것
    • MacBook Air Late 2010 - Working - High Sierra, Catalina, M2 Samsung Evo 860, Adapter
    • MacBook Air 2011 - Working - High Sierra, M.2 Transcend MTS830S SATA III, Long Adapter.
    • MacBook Air 2012 - Working - Catalina, M.2 Transcend MTS830S SATA III, Long Adapter.
    • MacBook Air 2013 - Unknown
    • MacBook Air 2014 - WD_black 500 + Sintech adapter, running MacOS Big Sur
    • MacBook Air Early 2015 - WORKING- Mojave 10.14.3 to Big Sur 11.0.1- Crucial P1 SSD NVME, Adapter.
    • MacBook Air 2017 - WORKING - High Sierra, Catalina and Big Sur, Monterey - Transcend MTE250S PCIe 4.0 4x NVMe, Long Adapter + Kapton Tape. / Transcend MTE260S PCie 5.0 (Testing, SSD works fine in Monterey 12.7.6 Blackmagic and AJA System Lite Disk Speed generate read errors. Employ only Amorphous Disk Test to Benchmark this PCIe 5.0 SSD.)
    • MacBook Air 2018 and forward - will not work, No removable drive
  1. MacBook Air 13" Early 2017 SSD Upgrade to NVMe, Lower Case: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2017 SSD Upgrade to NVMe: 3 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2017 SSD Upgrade to NVMe, Solid-State Drive: 4 단계, 이미지 1개 중 1개
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  4. MacBook Air 13" Early 2017 SSD Upgrade to NVMe: 5 단계, 이미지 2개 중 1개 MacBook Air 13" Early 2017 SSD Upgrade to NVMe: 5 단계, 이미지 2개 중 2개
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  5. MacBook Air 13" Early 2017 SSD Upgrade to NVMe, SSD - Alternate option using M.2 NVMe SSD: 6 단계, 이미지 2개 중 1개 MacBook Air 13" Early 2017 SSD Upgrade to NVMe, SSD - Alternate option using M.2 NVMe SSD: 6 단계, 이미지 2개 중 2개
    • Carefully insert the new SSD into the adapter, using the length of old drive as a reference for when the SSD is fully in the adapter. The lengths should be the same.
    • Insert the SSD and the adapter into the Socket, pushing inward in a straight fashion.
    • NVMe Drives can cause kernel panics due to sleep /hibernation issues. This can be turned off with the following command.
    • From a Terminal, use the following command to disable hibernation: ----"sudo pmset -a hibernatemode 0" ---- If you later want to enable hibernation, use: "sudo pmset -a hibernatemode 3"
결론
다른 43명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dan
회원 가입일: 02/18/19
4,985 평판
안내서 9개를 작성함
64가이드 댓글
I have a Macbook air 2017 1466this model https://support.apple.com/kb/SP753?local...
macOS Mojave ver 10.14.6. will your manual work?
l.cichon85 - 답글
Yes, this Manual will work for your Device.
Greets - Maik
Maikp735KR -
Thanks!
A little observation: the time estimate for the operation is 5 hours, is an error?
Blacy - 답글
5 hours will include the time needed to install OSX on the new drive. Swapping the drive is extremely fast
Dan -
Hi!.. Does anyone knows if the crucial SSD will work with the Macbook Air 13” 2017?
Thanks!
Francisco Rojas - 답글
댓글 쓰기
조회 통계:
지난 24시간: 34
지난 7일: 223
지난 30일: 1,270
전체 시간: 135,950
