주요 콘텐츠로 건너뛰기
MacBook Air 13" Early 2020 Left Speaker Replacement
필요한 것
  1. MacBook Air 13" Early 2020 Left Speaker Replacement, Remove the screws securing the lower case: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Early 2020 Left Speaker Replacement, Remove the lower case: 2 단계, 이미지 1/3 MacBook Air 13" Early 2020 Left Speaker Replacement, Remove the lower case: 2 단계, 이미지 2/3 MacBook Air 13" Early 2020 Left Speaker Replacement, Remove the lower case: 2 단계, 이미지 3/3
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  3. MacBook Air 13" Early 2020 Left Speaker Replacement, Disconnect the battery: 3 단계, 이미지 1/1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13" Early 2020 Left Speaker Replacement: 4 단계, 이미지 1/2 MacBook Air 13" Early 2020 Left Speaker Replacement: 4 단계, 이미지 2/2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13" Early 2020 Left Speaker Replacement, Disconnect the left speaker connector: 5 단계, 이미지 1/3 MacBook Air 13" Early 2020 Left Speaker Replacement, Disconnect the left speaker connector: 5 단계, 이미지 2/3 MacBook Air 13" Early 2020 Left Speaker Replacement, Disconnect the left speaker connector: 5 단계, 이미지 3/3
    • The left speaker will be on your righthand side when working on the MacBook, as it's laying upside down.
    • Slide the pointed end of a spudger underneath the left speaker cable and pry straight up to disconnect it from the logic board.
    • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  6. MacBook Air 13" Early 2020 Left Speaker Replacement, Remove the left speaker screw: 6 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the 4.2 mm screw securing the left speaker to the case.
  7. MacBook Air 13" Early 2020 Left Speaker Replacement, Remove the speaker's stretch-release adhesive: 7 단계, 이미지 1/3 MacBook Air 13" Early 2020 Left Speaker Replacement, Remove the speaker's stretch-release adhesive: 7 단계, 이미지 2/3 MacBook Air 13" Early 2020 Left Speaker Replacement, Remove the speaker's stretch-release adhesive: 7 단계, 이미지 3/3
    • Use a pair of tweezers to peel back the black pull tab on the speaker's stretch-release adhesive until you can grip it with your fingers.
    • Grab the adhesive strip's pull tab and slowly pull the adhesive strip out from underneath the speaker.
    • Keep the angle of the adhesive strip as parallel to the laptop as you can. Try to avoid dragging it across the inside of the case.
    • Pull the adhesive strip until it's freed from under the speaker.
    • If the adhesive strip breaks, use a heated iOpener, a heat gun, or a hair dryer to help remove the adhesive:
    • Apply heat to the speaker to soften the adhesive underneath.
    • Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
  8. MacBook Air 13" Early 2020 Left Speaker Replacement, Remove the left speaker: 8 단계, 이미지 1/2 MacBook Air 13" Early 2020 Left Speaker Replacement, Remove the left speaker: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    구매
    • Remove the left speaker.
    • During reassembly, to ensure the speaker performs as expected, install a strip of replacement adhesive on its underside before placing it back into the case.
결론
Carsten Frauenheim
회원 가입일: 03/10/20
112,591 평판
안내서 338개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,722개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 48
전체 시간: 1,957
