소개
Use this guide to replace the logic board in an Early 2020 MacBook Air.
Note that Touch ID will not function after replacing the logic board. The MacBook’s original Touch ID sensor is uniquely paired to the logic board at the factory—and without Apple’s proprietary calibration process, even a genuine replacement logic board from another MacBook Air won’t work.
If you replace the logic board, you must install a paired Touch ID sensor to retain Touch ID functionality.
필요한 것
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Use a T4 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
Remove the trackpad cable cover.
Use a pair of tweezers to peel back any tape covering the microphone cable connector.
Use the pointed end of a spudger to lift up the small locking flap on the microphone cable's ZIF connector.
Slide the microphone cable out of its connector.
Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
Slide the sound board cable out of the ZIF connector.
Use a T5 Torx driver to remove the six screws securing the logic board to the upper case:
Three 3.5 mm screws
One 5.8 mm cushioned screw
Two 2.0 mm screws
Battery cable
Fan cable
Audio board cable
USB-C board cable
Antenna bar cables
Trackpad cable
Left speaker and microphone cables
다른 10명이 해당 안내서를 완성하였습니다.
댓글 한 개
donde se ubica disco duro , ya que ledi opcion borrar mac y maraca error desde recovery
