주요 콘텐츠로 건너뛰기
MacBook Air 13" Late 2010 Lower Case Replacement
필요한 것
    • Before proceeding, power off the device, close the lid and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 9 mm 5-point Pentalobe screws
    • Eight 2.6 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  1. MacBook Air 13" Late 2010 Lower Case Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
577,384 평판
안내서 618개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 23
전체 시간: 10,149
