소개
Use this guide to replace your MacBook Air's removable solid-state drive (SSD).
동영상 개요
Remove the following ten screws:
Two 9 mm 5-point Pentalobe screws
Eight 2.6 mm 5-point Pentalobe screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
다른 20명이 해당 안내서를 완성하였습니다.
