소개
Use this guide to remove or replace the audio board in a Late 2020 MacBook Air (M1). The 3.5 mm audio jack is connected to this board.
필요한 것
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.3 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
Slide the pointed end of a spudger underneath the speaker cable and pry straight up to disconnect it.
Use the flat end of a spudger to pry the Touch ID cable straight up to disconnect it from the audio board.
Continue to slide the spudger underneath the Touch ID cable to release it from the audio board.
Use the flat end of a spudger to pry the audio board connector straight up to disconnect it from the board.
Remove the three screws securing the audio board:
Two 4.8 mm T5 Torx screws
One 2.5 mm T3 Torx screw
Use a spudger to pry the audio board out of the upper case until you can grip it with your fingers.
Remove the audio board.
다른 3명이 해당 안내서를 완성하였습니다.
