주요 콘텐츠로 건너뛰기
MacBook Air 13" Mid 2011 AirPort/Bluetooth Card Replacement
필요한 것
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  1. MacBook Air 13" Mid 2011 AirPort/Bluetooth Card Replacement: 2 단계, 이미지 1/1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 13" Mid 2011 AirPort/Bluetooth Card Replacement, Battery Connector: 3 단계, 이미지 1/2 MacBook Air 13" Mid 2011 AirPort/Bluetooth Card Replacement, Battery Connector: 3 단계, 이미지 2/2
    • As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Be sure to pull the connector horizontally toward the battery, and not straight up from the Air, or you may damage the socket on the logic board.
  3. MacBook Air 13" Mid 2011 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 4 단계, 이미지 1/2 MacBook Air 13" Mid 2011 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 4 단계, 이미지 2/2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  4. MacBook Air 13" Mid 2011 AirPort/Bluetooth Card Replacement: 5 단계, 이미지 1/1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  5. MacBook Air 13" Mid 2011 AirPort/Bluetooth Card Replacement: 6 단계, 이미지 1/2 MacBook Air 13" Mid 2011 AirPort/Bluetooth Card Replacement: 6 단계, 이미지 2/2
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
결승점
다른 25명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
583,553 평판
안내서 619개 작성하였습니다
댓글 9개
Is there any way to exchange the installed AirPort/Bluetooth Card with a newer one providing W-LAN AC?
Skyynet - 답글
Is tihs card is the same as in to Macbook Air 11 ?
Petar Slavchev - 답글
is it possible to renew on of the two antenna cables, because mine get broken while lifting it
milankoehnke1995 - 답글
Did you ever find the cables for sale anywhere? Thanks.
edwalker263 -
Can I replace this card with a newer one that allows Apple Watch unlock in Sierra?
Aaron - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 26
30일 전: 114
전체 시간: 45,082
