소개
Prereq for upper case (logic board is removed)
필요한 것
Remove the inner two 4.9 mm T8 Torx screws securing the right display hinge to the upper case.
거의 끝나갑니다!
결론
I did not remove the display assembly at all. I replaced both the trackpad and keyboard without removing the display assembly.
airshack - 답글
If you purchase the upper case with the keyboard as one unit you then have to remove the display assembly as the keyboard is part of the upper case
jheller105 - 답글
