이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the I/O board.
필요한 것
이 단계에 사용된 도구:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
다른 45명이 해당 안내서를 완성하였습니다.
댓글 8개
How can I tell if its my I/O board that is damaged? I cannot hear sound from Aux port or from the speakers on my macbook. Laptop still charges fine though.
