소개
이 안내서를 따라서 2019 MacBook Air의 배터리를 안전하게 분리하세요.
손상 위험을 최소화하려면 이 절차를 시작하기 전에 MacBook을 켜고 배터리를 완전히 방전하세요. 충전된 리튬-이온 배터리에 실수로 구멍이 나면 위험할 수 있습니다. 배터리가 부풀어 올랐다면, 추가 예방 조치를 취하세요.
필요한 것
MacBook이 Big Sur v11.1 이상을 사용하는 경우, 자동 부팅을 비활성화 하지 못할 수도 있습니다. 절차를 정상적으로 진행하세요, 하지만 내부로 진입하는 즉시 배터리를 분리하세요.
P5 드라이버를 사용하여 다음 나사들을 풀어주세요:
7.9mm 나사 두 개
7.1mm 나사 두 개
2.6mm 나사 여섯 개
디스플레이와 하단 케이스 사이에 손가락을 넣어 위로 당겨 하단 케이스를 Air에서 분리하세요.
하단 케이스를 분리하세요.
Are there any suggestions to removing the pressure fasteners more easily?
Spudger/스퍼저를 사용하여 배터리 커넥터를 로직 보드와 평행하게 밀어 로직 보드 소켓에서 빼세요.
Before the battery can be fully disconnected, the battery disconnect button needs to be held down. There is a gold button just above the battery socket, along with a small LED much like the 12” machines. Once this has been held down and the LED has switched off it is safe to remove the battery.
This seems like an important step?
Also, seems like this should be done after the battery is disconnected, not before? Otherwise, wouldn’t the battery re-charge it?
What if the white LED dosent light up after pressing the yellow button again?
Iron05 -
I just performed this repair on my late 2018 mac air. I did click the gold button but saw no LED illuminated or otherwise. Question- after reassembly does the button get pressed again to connect the battery? Please clarify if this button is to be pressed and if it needs pressing again after the repair.
All said - I pressed again after the battery connector clicked, assembled the back and all worked perfectly. The original issue was one dead port (no charge, no communication). The battery charge lightening bold icon was acting funny too. Genuis bar guy in Naperville said it was likely a logic board too. But it was not. The port was apparently confusing the logic board with regards to the charge function. Thanks Adam for saving me $440 and sending my computer back to Apple. I am 71 yrs young - who says an old dog can’t learn new tricks with good training!!
I didn't see Aaron's comment before completing the battery replacement. Afterwards, the computer would not turn on despite multiple SMC reset procedures. Upon double-checking the comments I see the importance of pressing the gold button. I pressed the gold button before disconnecting the new battery, then pressed it again after reconnecting for good measure. Computer booted!
It would be good of iFixit to add this important step as most people probably don't open up every single comment on (seemingly) simple steps.
Seconding Corey's comment. If paid more attention to the comment section, I would have avoided 15-30 minutes of panic. (BTW I did not notice any LED, but the golden button was easy to find).
Where is the gold button? I replaced my battery and my laptop will not start
핀셋을 사용하여 오른편 스피커 하단의 검정색 접착 당김 탭을 손가락으로 잡을 수 있을 만큼 충분히 들어 올리세요.
접착 스트립 당김 탭을 잡고 접착 스트립을 스피커 아랫면에서 천천히 그리고 조심히 잡아 당기세요.
접착 스트립이 끊어지면, 그대로 놓아 두고 다음 단계로 진행하세요.
What do you do to get the speaker to stick once you put things back together? Are these adhesive strips reusable? If not, where can we get new ones?
The strips will tend to remain edhesive in some cases but if not just use some thin double sided adhesive tape of a similar width. I will not link because I am in Australia but it isn’t hard to find. I used some heat (100°C) and a plastic spudger to aid removal or a hair dryer on lower heat. Slow and steady, it’s not hard. The strips will almost certainly break.
Spudger/스퍼저 끝을 오른편 스피커 케이블 밑에서 밀고 똑바로 들어 올려 스피커를 분리하세요.
Broke both speaker connectors by spudging straight up. Looks like they should slide apart like a normal zif.
Pulled straight up and broke both connectors.
핀셋을 사용하여 오른편 스피커 상단에서 접착 당김 탭을 손가락으로 잡을 수 있을 만큼 충분히 들어 올리세요.
스피커에 열을 가하여 아랫면의 접착제를 부드럽게하세요.
스피커 아랫면으로 spudger/스퍼저 또는 여는 픽을 밀어 접착제를 분리하세요.
This business of pulling the adhesive out (here and with the batteries) - at first it seems impossible, but persevere. Pull it really, really, slowly - it extends to around 30cm before it's all out. I applied a bit of heat with a heat gun (at least with the batteries) and after a few failed attempts got the hang of it. When it works, it's like magic and very satisfying, and much better than giving up and prising the part off with the adhesive in place.
오른편 스피커를 하단에서 들어 올려 분리하세요.
Step 5 the right speaker adhesive broken while removing, other end adhesive slipped out ok. But it's extremely hard to now lift up the battery, feels like I break something if I try harder.
handsonmac - 답글
This is not as easy as it sounds. Neither adhesive strip broke, but that bugger resists removal, because it is attached with adhesive tape to the bottom. Use different angles of attack to pry it up with steady force.
핀셋을 사용하여 왼편 스피커 하단의 검정색 접착 당김 탭을 손가락으로 잡을 수 있을 만큼 충분히 들어 올리세요.
T3 Torx/톡스 드라이버를 사용하여 트랙패드 커넥터 브래킷을 고정하는 1.4mm 나사 두 개를 풀어주세요.
트랙패드 커넥터 브래킷을 분리하세요.
My machine used T4 screws
Me too! I tried with T3 and it wasn’t working.
I stripped my screws trying to get them out with a t3 driver...
T3 Torx/톡스 드라이버를 사용하여 USB-C 포트 커넥터 브래킷을 고정하는 1.3mm 나사 두 개를 풀어주세요.
USB-C 커넥터 브래킷을 분리하세요.
There is no need to remove the logic board!!
Skip steps 16 through 28 and go to step 29 to release the trackpad cable from the battery. then follow steps to 30 through 33 to release the battery. The battery can be removed by slipping it counter-clockwise under the trackpad cable. The new battery can be slipped in place in the same way.
Much easier!!
josephgray - 답글
Removing a few of the logic board screws allowed me to get the to right screw bracket under the logic board to give enough clearance as w98fxr mentioned.
This can be done, but it's very tight. Still, beats removing the logic board and the possibilities of breaking something in the process.
maccentric - 답글
Spudger/스퍼저의 평평한 끝을 사용하여 USB-C 케이블 커넥터를 위로 들어 올려 로직 보드의 소켓에서 빼세요.
please reconsider removing the logic board and and usb-c connector as is recommended in the prior step. i had a very difficult time reconnecting the usb-c connector
T3 Torx/톡스 드라이버를 사용하여 안테나 케이블 브래킷을 고정하는 1.4mm 나사를 두 개를 풀어주세요.
안테나 케이블 브래킷을 분리하세요.
These are T4 screws
The MBA I just finished with were T3. I'm fairly confident with my tools as I recently updated/upgraded nearly my entire set with WiHa. I should also mention the many tools acquired from iFixit over the years have all been were exceptional lasting years. There's no doubt iFixit would have been my source but a close friend went to work for WiHa. His discount(s) & being motivated to help him was a major impact. For anyone not having such an advantage IMHO tools from iFixit are one of the best values anywhere. Let's not forget; buying from iFixit will also help to push "Right to Repair" forward. Here in Minnesota Right to repair ALMOST PASSED. Many believe it will become law during the next session! I can't tell you how proud this would make me. I would obtain as many service manuals as possible and post them all online!!! What a great dream...
커넥터와 가까운 안테나 케이블 중 한 개 밑으로 spudger/스퍼저 끝을 넣으세요. 케이블을 똑바로 들어 올려 분리하세요.
다른 안테나 케이블에 반복하세요.
Be SUPER SUPER CAREFUL pulling off the gold WiFi antenna connectors! As described, use the spludger to press up the black cable just behind the metal connector. I tried to ping them off from the bottom of the gold connector where it clips into the socket on the motherboard and ended up pulling off the SMD sockets from the motherboard - huge and costly mistake that will probably render it useless.
Spudger/스퍼저의 평평한 끝을 사용하여 디스플레이 케이블 커넥터를 들어 올리세요.
How do I reconnect display connector??
Kris Queck - 답글
Just align the plug section of the display flex with the socket on the logic board and gently press it in until it locks in place. Do not force it but just ensure it’s correctly aligned before pushing it into the socket.
Pro tip: You can remove the two T5 screws on the LCD connector side (located to the right of the display connector and to the left of the heat shield). From there, tilt the whole skinny LCD board towards the logic board connector and gently pinch the connector in to the socket. Before laying the skinny board back down, screw in the shield from Step 15 so it doesn’t pop out of the socket again.
T4 Torx/톡스 드라이버를 사용하여 다음 나사를 풀어주세요:
5.5mm 나사 한 개
2.6mm 나사 세 개
1.9mm 나사 두 개
These are T5 Torx driver screws
Need torx 5 AND torx 4 driver here ;)
During re-assembly be soft when screwing in the logic board because those antenna plugs in Step 14 are quite awkward to pin back into their sockets and there is little leeway in the cables; to make this task a little easier in Step 14, secure the logic board loosely right up against the near outside edge; after re-connecting all the cables in Steps 16-9, return to Step 17 to firm up the logic board screws.
This tip was a huge help, hate these cables lol
The 5.5 mm screw goes into a hexagon standoff which may come off with the logic board being sanswiched beteen the 5.5 mm screw screw and the standoff like happened to me. Just something to be aware of. It also has a black rubber bumper over the screw which was not mentioned at all. It pulls straight off to give access to the screw.
On my board I needed to use T6 for all the screws except the rubber bumper for which I used a T7. I have a full set of small Torx drivers and tried for the best fit.
jeffyouell - 답글
T5 fit best is all the screws on my machine
Spudger/스퍼저의 평평한 끝을 사용하여 트랙패드 ZIF 커넥터의 작은 잠금 덮개를 들어 올리세요.
트랙패드 케이블을 커넥터에서 똑바로 밀어서 빼세요.
핀셋을 사용하여 배터리 측면의 검정색 접착 당김 탭을 손가락으로 잡을 수 있을 만큼 충분히 들어 올리세요.
접착 스트립 당김 탭을 잡고 접착 스트립을 배터리 아랫면에서 천천히 그리고 조심히 잡아 당기세요.
배터리를 분리하세요.
새로 설치한 배터리를 보정하세요: 배터리를 100% 충전한 다음 최소 두 시간 더 충전하세요. 그런 다음 플러그는 뽑고 정상적으로 사용하여 배터리를 방전하세요. 배터리 부족 경고가 나타나면 작업을 저장하고 배터리 부족으로 인해 절전 모드가 활성화될 때까지 노트북을 켜놓으세요. 최소한 5시간 이상을 기다리고 나서 노트북을 중단없이 100% 충전하세요.
새 교체 부품을 원래 부품과 비교하세요—설치하기 전에 나머지 부품을 옮기거나 새 부품에서 접착 뒷면을 제거해야 할 수 있습니다.
기기를 재조립하려면, 위의 단계들을 역순으로 따르세요.
전자 폐기물을 R2 또는 e-Stewards 인증 재활용 센터로 가져가세요.
수리가 계획대로 진행되지 않았습니까? 자사의
답변 커뮤니티에서 문제 해결 도움을 받으세요.
다른 24명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 5개
Great repair guide but the logic board screws are Torx T5 (not T4) at Step 25 of guide
Thanks! I would never have guessed everything that needed to be done without this guide. Man, I HATE the tiny, tiny screws. Lost one even after sticking all the screws to tape, just in case. :( Took the full hour to put in in, but the new battery is charging like new.
K L DeWitt - 답글
If the first thing you do is disconnect the battery, is it really an issue if you don’t (or can’t) disable auto-boot?
maccentric - 답글
I agree, why disable Auto-Boot when the lid is closed and the battery is disconnected immediately? – I've never had an issue since 2016 when the feature was introduced.
stevebsiegel - 답글
On my machine, the longest two screws were in the corners, while the other two long screws were in the middle. Perhaps previous service in the past had them replaced into the wrong place? In any case, the longest screws do seem to fit in either place. I guess 0.8mm is not very much of a difference. Seems like poor design if they could have used one size of screw.
johann beda - 답글
Just did one, and it also had longest screws in the corners.
maccentric -
Just did another, and the long ones were in the middle. Definitely poor design and quality control.
maccentric -
