주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.6 mm screws (with a 2.7mm collar)
    • Two 7.1 mm screws
    • Six 2.3 mm screws
  2. Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
  3. Remove the plastic shield covering the battery PCB. Remove the plastic shield covering the battery PCB.
    • Remove the plastic shield covering the battery PCB.
  4. Use a T3 torx driver to remove two 2.3mm screws from the battery PCB: Use a T3 torx driver to remove two 2.3mm screws from the battery PCB:
    • Use a T3 torx driver to remove two 2.3mm screws from the battery PCB:
  5. Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board. Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  6. Use a T3 Torx driver to remove the one 1.1 mm screw securing the antenna cable bracket. Remove the antenna cable bracket.
    • Use a T3 Torx driver to remove the one 1.1 mm screw securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  7. Insert the point of a spudger under one of the antenna cables close to the connector.
    • Insert the point of a spudger under one of the antenna cables close to the connector.
    • Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  8. Use a T3 Torx driver to remove the two 1.3 mm screws securing the display cable connector bracket. Remove the display cable connector bracket.
    • Use a T3 Torx driver to remove the two 1.3 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  9. Use the flat end of a spudger to pry up the display cable connector. Use the flat end of a spudger to pry up the display cable connector.
    • Use the flat end of a spudger to pry up the display cable connector.
  10. You can skip this step if your replacement display assembly comes with these two brackets preinstalled. Use a T3 Torx driver to remove the two 1.1 mm screws securing the flex cable brackets.
    • You can skip this step if your replacement display assembly comes with these two brackets preinstalled.
    • Use a T3 Torx driver to remove the two 1.1 mm screws securing the flex cable brackets.
    • Remove the two brackets.
  11. Use a T5 Torx driver to remove the following screws:
    • Use a T5 Torx driver to remove the following screws:
    • Four 7.1 mm screws
    • Two 4.2 mm (Black) screws
  12. Lift the antenna bar straight up and out of the case. Take care not to snag the antenna bar on any cables or connectors. You may encounter resistance from the clips in the middle of the antenna bar holding it in the case. You may pull hard without damaging anything as long as you pull straight up, perpendicular to the case. Remove the antenna bar.
    • Lift the antenna bar straight up and out of the case. Take care not to snag the antenna bar on any cables or connectors.
    • You may encounter resistance from the clips in the middle of the antenna bar holding it in the case. You may pull hard without damaging anything as long as you pull straight up, perpendicular to the case.
    • Remove the antenna bar.
  13. Use a T9 Torx driver to remove the six 4.7 mm screws securing the display hinges to the upper case. Use a T9 Torx driver to remove the six 4.7 mm screws securing the display hinges to the upper case.
    • Use a T9 Torx driver to remove the six 4.7 mm screws securing the display hinges to the upper case.
  14. With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible. With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible.
    • With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible.
  15. Carefully rotate the upper case to a 90 degree angle with the display. The hinges should not move in relation to the display, and should rotate out of the case slightly.
    • Carefully rotate the upper case to a 90 degree angle with the display.
    • The hinges should not move in relation to the display, and should rotate out of the case slightly.
    • Keeping the display flat, tilt the upper approx 5-10 degrees to the left. Move the upper case to the right, the hinges should easily slide out of the upper case.
  16. Display should now be separate from the upper case.
    • Display should now be separate from the upper case.
결론
다른 2명이 해당 안내서를 완성하였습니다.
David Fear
회원 가입일: 2011년 09월 08일
3,483 평판
안내서 2개 작성하였습니다
Pickle IT Pickle IT 회원
Business
2 회원들
안내서 6개 작성하였습니다
Great guide! Did you encounter any tamper-proof seals? Anything that would make it obvious that the MacBook was disassembled?
Yann Landry - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 66
전체 시간: 295
