주요 콘텐츠로 건너뛰기
MacBook Air 13" Retina Display 2020 Smaller Keys Replacement
필요한 것
  1. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement, Smaller Keys: 1 단계, 이미지 1/1
    • Clean the keyboard.
  2. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 2 단계, 이미지 1/2 MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 2 단계, 이미지 2/2
    • Gather all necessary pieces that may have come off with the key.
    • The key itself.
    • The hinge piece.
    • Orient the hinge piece in the proper position.
  3. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 3 단계, 이미지 1/3 MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 3 단계, 이미지 2/3 MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 3 단계, 이미지 3/3
    • Install onto single mount first.
    • Then press into the double mount.
    • Make sure the hinge is in place properly, or the key will not stay on.
  4. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 4 단계, 이미지 1/1
    • This piece, the rubber cap, doesn't come off often. But if it does, you can reinstall it by pressing down on the middle.
  5. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 5 단계, 이미지 1/2 MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 5 단계, 이미지 2/2
    • Orient the key in the proper position.
  6. MacBook Air 13" Retina Display 2020 Smaller Keys Replacement: 6 단계, 이미지 1/1
    • Press the key down into place.
결론
To disassemble your device, follow these instructions in reverse order.
Brianna Kwiecinski
회원 가입일: 03/18/21
139 평판
안내서 1개 작성함
댓글 한 개
Is this strictly for the early 2020 MacBook Air, or will this same technique work for the late 2020 MacBook Air?
iannai29 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 37
30일 전: 192
전체 시간: 4,543
