이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
Disconnect the battery connector by pulling it straight out of its socket.
Remove the following nine screws securing the battery to the Air:
Four 2.9 mm Phillips.
Four 3.8 mm Phillips.
One 7.2 mm Phillips.
Lift the battery out of the Air.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
Pull the audio out ribbon cable off the adhesive securing it to the upper case.
Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
Disconnect the audio out cable from its socket on the port hatch ribbon cable.
Use a spudger to pry the hard drive cable connector up off the logic board.
Use the sharp end of a spudger to de-route the microphone cable from the hard drive bracket.
Remove the cosmetic screw cover from the adhesive securing it to the hard drive bracket.
Remove the four Phillips screws securing the hard drive assembly to the upper case:
Two 4.7 mm screws.
Two 3.9 mm screws.
Use the tip of a spudger to pull the fan cable connector straight away from its connector on the logic board.
One 5.9 mm Phillips screw.
Two 1.9 mm Phillips screws.
One 1.9 mm Phillips screw.
One 5.0 mm Phillips screw
Five 1.9 mm Philips screws.
One 2.5 mm Phillips screw.
Disconnect the microphone cable by pulling its connector straight away from the socket on the logic board.
Remove the two small Phillips screws securing the logic board bracket to the upper case.
Lift the logic board bracket out of the upper case.
Use a spudger to pry the AirPort/Bluetooth and trackpad control cable connectors up off the logic board.
Disconnect the DC-In cable by pulling its connector straight away from the socket on the logic board.
Remove the small Phillips screw securing the display data cable ground loop to the upper case.
Disconnect the display data cable by pulling its connector straight away from the socket on the logic board.
Remove the three Phillips screws securing the logic board to the upper case.
Remove the two following screws securing the AirPort/Bluetooth board bracket to the upper case:
One 4.7 mm Phillips.
One 3.9 mm Phillips.
Use a spudger to pry the three antenna cables up off the AirPort/Bluetooth board.
Peel the antenna cables up off the adhesive securing them to the upper case.
Remove the single Phillips screw securing the microphone cable ground loop to the upper case.
Open the Air so the display is perpendicular to the upper case and place it on a table as shown.
While holding the top of the Air with one hand, remove the T6 Torx screw from the lower display bracket.
Pull the upper case straight away from the display, minding any cables that may get caught.
다른 116명이 해당 안내서를 완성하였습니다.
댓글 7개
Great guide. I was able to remove the components without any trouble. Be sure to label your screws, as there are so many.
Do you have a guide to put that macbook back togerher?
I was able to replace broken hinges without replacing the whole display. It takes patience and a bit of courage but it's doable (except if you are blonde and cute I guess ;)
Buenas tardes Alberto. Tengo necesidad de sustituir una bisagra de este modelo y no sé donde puedo adquirirla. Le agradecería que me dijera donde puedo comprarla. muchas gracias por adelantado
