주요 콘텐츠로 건너뛰기
MacBook Air Models A1237 and A1304 Hard Drive Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Air Models A1237 and A1304 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 MacBook Air Models A1237 and A1304 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 MacBook Air Models A1237 and A1304 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
    • Pull the audio out ribbon cable off the adhesive securing it to the upper case.
    • Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
  2. MacBook Air Models A1237 and A1304 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Disconnect the audio out cable from its socket on the port hatch ribbon cable.
  3. MacBook Air Models A1237 and A1304 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Use a spudger to pry the hard drive cable connector up off the logic board.
  4. MacBook Air Models A1237 and A1304 Hard Drive Replacement: 4 단계, 이미지 1/2 MacBook Air Models A1237 and A1304 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Use the sharp end of a spudger to de-route the microphone cable from the hard drive bracket.
    • Remove the cosmetic screw cover from the adhesive securing it to the hard drive bracket.
  5. MacBook Air Models A1237 and A1304 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Remove the four Phillips screws securing the hard drive assembly to the upper case:
    • Two 4.7 mm screws.
    • Two 3.9 mm screws.
  6. MacBook Air Models A1237 and A1304 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Lift the hard drive assembly out of the upper case.
결론
Walter Galan
694,676 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 9,672
