주요 콘텐츠로 건너뛰기
MacBook Air SSD Replacement
필요한 것
  1. MacBook Air SSD Replacement, SSD: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case.
    • The two screws on the edge containing the hinge are longer than the others.
    • The eight screws in the corners and remaining edges are shorter.
  2. MacBook Air SSD Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air SSD Replacement: 3 단계, 이미지 2개 중 1개 MacBook Air SSD Replacement: 3 단계, 이미지 2개 중 2개
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air SSD Replacement: 4 단계, 이미지 1개 중 1개
    • Remove a single T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air SSD Replacement: 5 단계, 이미지 2개 중 1개 MacBook Air SSD Replacement: 5 단계, 이미지 2개 중 2개
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Austin Blakely
회원 가입일: 03/11/19
22,203 평판
안내서 53개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,605개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 99
지난 7일: 930
지난 30일: 3,949
전체 시간: 52,667
