이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
Lift the memory cover up and out of the computer.
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
Remove the following 3 screws from the rear wall of the battery compartment:
One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screws.
Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
Remove the following 4 screws from the back of the computer:
Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Remove the two Phillips screws from the optical drive (right) side of the computer:
Two 5.2 mm Phillips #00, with shank (2.3mm dia. x 3.25 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
이 단계에 사용된 도구:Plastic Cards$2.99-
Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
Disconnect the MagSafe board cable from the logic board by pulling the snap-in connector out (to the right).
Remove the single 9 mm Phillips screw securing the left speaker to the lower case.
Lift the left speaker out of its housing and set it to the side.
Two 7.5 mm Phillips from either end of the left I/O frame.
One 9 mm Phillips from the middle of the left I/O frame.
Remove the small black plastic spacer at the bottom of the left I/O frame.
Lift the left I/O frame up and out of the computer. Pay attention to the thin metal EMI fingers, as they may catch as you remove the left I/O frame.
다른 15명이 해당 안내서를 완성하였습니다.
