소개
Access the combo or SuperDrive.
부품
지정된 부품이 없습니다.
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
Remove the following 4 screws from the back of the computer:
The longer screws go on the inside, shorter screws on the outside.
Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
While holding up the upper case, pull up the black tab of the silver cable away from its connector.
While you have the upper case removed, you may want to take the opportunity to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
다른 3명이 해당 안내서를 완성하였습니다.
